Environmental controls have no power
Old Mar 25, 2007 | 10:43 PM
rattlesnake_dm's Avatar
Car: 1992 RS (25 th Anniversary)
Engine: 350 Miniram XFI
Transmission: Pro-Built 4L60
I have a 1992 Camaro RS that I swapped out the 305 TBI engine for a 1991 350 TPI engine. I have all the engine wiring for the TPI engine plus the 730 ECM. I did the swap and got the engine to run fine, no SES lights or codes. I did the wiring for the speedometer too and got that working. But I now have no heat or A/C. The blower motor doesn't come on at all. The blower worked before the swap. Has anyone run into this problem. Is there a difference in the bulkhead connector pinouts for a 1992 TBI car and a 1991 TPI car. All I did was use the 1991 engine harness and plug it into the 1992 bulkhead.
Old Mar 27, 2007 | 05:30 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Re: Environmental controls have no power
I lost my Blower motor when I installed an AC delete box, it was because the resister shorted on the blower case and blew the fuse, did you check that?
deracer
Apr 11, 2016 12:04 AM
1986Z28OWNER
Dec 13, 2015 10:19 PM
sailtexas186548
Aug 24, 2015 10:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
stalkier
Aug 13, 2015 12:59 PM
