Can the car support....
Old Mar 26, 2007 | 02:57 PM
Shawn Ryback's Avatar
Car: Firebird 1989
Engine: 2.8 Litre
Transmission: Automatic
I want to add two LCD monitors to my car it say's they come with a 12v plug will that pull too much power and blow a fuse? the plug in the ash tray is connected to a 20 amp fuse will it blow out?
and if so how do I install them and not have that problem?
Old Mar 26, 2007 | 03:48 PM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Re: Can the car support....
Depends on the power draw of the monitors. You might consider wiring a discrete circuit with a fuse for each one from a good keyed power source.
Old Mar 26, 2007 | 06:12 PM
Car: Firebird 1989
Engine: 2.8 Litre
Thank my Auto Brother...
Old Mar 26, 2007 | 06:25 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I think it will work, my LCD monitor only pulled a few amps at the most. Find the current ratings and add them up- if it pops a fuse then check here how to wire it up properly.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
