Wiring 4th gen lock switches
Old Mar 28, 2007 | 05:14 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
Before you say it, yes, i searched. And searched, didnt find anything.
Basically, I almost have this door done. 4th gen panel fits, handle is on, window and mirror switches are wired up, but I'm having some difficulty with the power lock switches. Using this schematic from my 91 Z ...
And this schematic ..
http://shbox.com/1/keyless_schematic.jpg
What am I missing? The 3rd gen switch has 3 wires, Orange, Black, and Lt. Blue. The 4th gen switch has 5 Orn/Blk, Lt Blu, Dk Blu, Orn, Red/Blk. I KNOW the two ORN wires go together, (+12v), but am unsure about the others. Any ideas?
Old Mar 28, 2007 | 05:31 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
Re: Wiring 4th gen lock switches
What year 4th gen are your switches from? When I looked up a 97 and 01 they only used 3 wires.
Old Mar 28, 2007 | 05:42 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Transmission: 4L60
94 or 95 Firebird switches.
Old Mar 28, 2007 | 05:48 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Transmission: 4L60
According to the diagrams, I wired as follows ..
3rd Gen to 4th Gen
ORN (+12v) ORN
Lt Blu (Lock) Orn/Blk
Blk (Unlock) Red/Blk
That takes care of the 3 wires on the 3rd gen harness. I'm left with a Lt Blu and a Dk Blu on the 4th gen switch, which I ran to the Lt Blu and Dk Blu on the RH side switch. The ORN on the RH switch to the other ORN (+12v), and the 2 blacks to ground. No go.
Old Mar 28, 2007 | 07:53 PM
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Using the stock 3rd gen harness connect it like this
3rd Gen to 4th Gen
Left Side
ORN (+12v) ORN
Right Side
ORN (+12v) ORN
Lt Blu (Lock) Lt Blu
Blk (Unlock) Dk Blu
Leave all other wires unattached.
Mike
Old Mar 28, 2007 | 09:16 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Transmission: 4L60
I just connected the left side as its the only one with everything in place at the moment. Still no go.
Old Mar 28, 2007 | 09:42 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
Me thinks you got the wrong pigtail with your switches. The 4th gen switches have 5 pins on them, but two are locating pins only. There's only three wires on stock 4th gen pig-tails.
The connector is universal GM, and does have 5 holes and spots for two more wires. Given you have extra wires I think you can throw the colors of them out the window. I can check again, but I believe the lowest pin on the three pin side isn't connected and the diagonal opposite pin on the two pin side isn't connected.
It would be easy to check with a multi meter. Check for shorts between two wires as you push the button up/down.
Kevin D.
Old Mar 28, 2007 | 10:09 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Transmission: 4L60
Thanks, I'll have to check that out tomorrow ...
Old Mar 29, 2007 | 03:43 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Transmission: 4L60
Still no go. I have continuity between ALL the wires and where they should go according to the schematic. So, no shorts. Fuse is good, power to the relay, and power at the ORN wire at the switch, so I am kind of leaning towards a relay. How do you test a circuit breaker? Can you?
Old Mar 29, 2007 | 06:18 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Transmission: 4L60
Well, wasnt the relay. Could I just have 2 bad actuators? Anyone have any other ideas? Kevin, any chance you could pop off the cover plate on yours and check the wiring colors?
Old Mar 30, 2007 | 03:14 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Transmission: 4L60
Bump, anyone?
Old Mar 30, 2007 | 04:28 PM
kubus_stroinski's Avatar
Car: 1991 Camaro RS
Axle/Gears: Tru-Track posi/Moser axles/4.10
try wiring up your old thirdgen switches again to make sure everything still works. if it does then you either know that you're wiring up the new ones incorrectly or the new ones just dont work properly and you'll need to get a new set
Old Mar 30, 2007 | 07:06 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Transmission: 4L60
Found the problem, was missing a ground. Thanks guys for the input.
Old Apr 23, 2010 | 10:01 AM
cyberleader's Avatar
Car: 2002 Z28
Engine: 5.7 Stock
Axle/Gears: Stock
when i follow the instructions above i get only unlock...
Old Apr 29, 2010 | 10:59 PM
Car: 2002 Z28
Engine: 5.7 Stock
Axle/Gears: Stock
got it. what worked for me was (both sides)
3rd gen > 4th gen
Orange > Black
Lt Blue > Red
Black > Orange
Finally got all my 4th gen wiring done and working. I'd like to thank everyone on this board for all their help. Cheers!
Old Jul 21, 2014 | 10:58 PM
Tj_sa's Avatar
Car: 1990 Chevrolet Camaro
Transmission: 4l60e
Axle/Gears: 10 bolt 3:73
------ I'm dyin to figure out how you wired your 4th gen window switches, I have a show coming soon and my switches are my last piece to my entire interior swap. Please help
BRoss99
Aug 10, 2025 05:08 PM
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Casey Meyers
Mar 2, 2016 10:46 AM
