power trunck problem
Old Mar 30, 2007 | 07:47 PM
88ttopta's Avatar
i just bought a 88 ta and i love it.just one small problem.the power trunck mecanism went all the way down as if the trunck was fully closed, the hatch is open and the motor just keeps running.i had to unplug it so my battery doesnt go dead .i need some help.thanx chris
Old Mar 30, 2007 | 08:39 PM
j dezzy's Avatar
Car: 87 TA
Re: power trunck problem
Sounds like the reverse switch is bad.
Old Mar 30, 2007 | 09:11 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Go to the TDS site and read their instructions about the pull down hatch. Most common problem is stripped gear nut. Been there and done it.
Old Mar 30, 2007 | 10:55 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Agreed. "motor keeps running" = "broken gear nut"
Check the Tech article I wrote on TGO for instructions on repairing the 1986-87 & 88-91 hatch pull-down units.
Stuck down without the motor running could be a bad reversing switch or more likely the unit just needs to be re-set. The pull-down unit only runs on the down cycle if the striker-sensing switch is pressed. To re-set the pull-down unit is simple. Just reach down into the hole that the latch portion retracts into and press on the striker-sensing switch. That switch is located just in front of the latch as you face the pull-down from the rear of hte car. Presing the switch SHOULD cause the motor to turn on and power down until the reversing switch is tripped. You'll hear a CLICK when that happens. The motor will turn off at that point. Release the switch and it should power all the way back up and be re-set. There are seversl reasons why the pull-down unit needed to be re-set . Most commonly the hatch hook contacted the striker-sensing switch but failed to be latched. The pull-down started it's downward cycle until the hatch closed. At that point the motor continued down but the hatch hook came off of the switch. The motor stops immediately. Re-setting as described is necessary at that point.
88ttopta needs a new gear nut. I just listed the instructions for re-setting the pull-down unit for anyone else that needs to know.
Lon Salgren
Top-Down Solutions
Old Mar 31, 2007 | 07:20 AM
DJP87Z28's Avatar
Lonsal
If everyone would read that article first they could solve 99 44/100% of the problems.
jhawkeye
May 25, 2022 06:33 PM
355tpipickup
Aug 27, 2015 08:13 AM
neekolzun
Aug 24, 2015 04:59 PM
Bert87
Aug 23, 2015 03:50 PM
db057
Aug 22, 2015 08:17 PM
