My headlights suck
Old Apr 9, 2007 | 08:41 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
My headlights suck
Hi, how would I get my headlights brighter? I know I could get a higher output bulb, and a bigger ballast, but what would you guys suggest? I only get about 30 meters of visibility, so if a dog, or moose were to jump infront of me, my firebird could become ground beef.. Thanks, KP.
Old Apr 9, 2007 | 09:37 PM
subliminal's Avatar
Re: My headlights suck
HID Conversion.
Old Apr 10, 2007 | 05:59 AM
Kevman's Avatar
Engine: 2004 LQ4
I read the Tech Article, but it doesn't have a wiring diagram for a firebird..
Old Apr 10, 2007 | 10:40 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
What headlights are you running now? Get a set of halogens from autozone or something, you should be able to find something brighter. That's what I did and I can see fine.
Old Apr 10, 2007 | 12:06 PM
subliminal's Avatar
Just buy a set of sylvania silver star headlights direct replacement for yours and alot brighter than stock.
Old Apr 10, 2007 | 07:06 PM
Kevman's Avatar
Engine: 2004 LQ4
I'm running factory headlights I believe. I can hardly see anything at all. How much would those Silver Star headlights run for?
Old Apr 10, 2007 | 07:14 PM
I believe I picked them up for like 12$ a light or some jazz like that. It was a year ago so my mind is fuzzy, but they arent expensive. Well worth the $$ if you can't see right now.
Old Apr 10, 2007 | 07:57 PM
pairtoe's Avatar
silvers stars are the best bang for your buck with out a doubt.
Old Apr 10, 2007 | 08:35 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
I bought the silverstars and made a huge difference.then i adjusted my headlights and it was a world of difference.Thats the best and easiest way to upgrade your lights until you decide to start buying aftermarket stuff.With the sylvanias i dont need anything else,especialy with fog lights.
Old Apr 10, 2007 | 11:12 PM
Oh yeah thats a good point, make sure you adjust the lights correctly with the screws on the tops and bottoms of the headlight bezels. If you have one light pointed straight down, then you wont be able to see far, but if you raise it up a bit it will do a world of wonders.
3.8TransAM
Oct 1, 2015 07:47 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
