Elp needed to find speed sensor wire and rev counter wire
Old Apr 10, 2007 | 03:47 PM
pbryant_knight's Avatar
Help needed to find speed sensor wire and rev counter wire
Hi All,
I know third gen.org are great at sorting out problems and have a vast amount of cumulitive knowledge.
i have a 1991 firebird 3.1 V6.
My problem is this: I'm trying to wire up an aftermarket Cyberdine digital speedo and velleman digital rev counter into my dash. I have everthing ready to install but i cant locate the wire that sends the speed signal and rev counter signal to wire up to my new gauges.
When i removed my old cluster, there are 2 14-pin connectors that plug into the clusters printed curcuit board. Where will i find the signal wires. i've looked at the wires going into the connectors and drawn a diagram with the rough colours on.
Any help would be appreciated.
Cheers
Peter
Attached Thumbnails Elp needed to find speed sensor wire and rev counter wire-behind-dials.jpg   Elp needed to find speed sensor wire and rev counter wire-4-pin-connectors-layout.jpg
Old Apr 12, 2007 | 05:28 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
Re: Elp needed to find speed sensor wire and rev counter wire
I'm pretty sure the white wire is the tach wire, I'll verify when I get home and check the GM service manual tonight. I'll have the VSS wire too.
Old Apr 13, 2007 | 09:41 AM
Cheers. i've found the speedo wire. it was the yellow one coming from the back of the transmition. still having difficulty finding the tach. when you say white, you mean white from the back of the 14 pin socket connector? so i could just take it from there?
Cheers
Peter
Old Apr 13, 2007 | 10:15 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Open the ATGO wiring diagram page, scroll down to the instrument panel diagrams. You'll find pinouts there for those two connectors. Courtesy of myself truly. I got tired of not knowing what pin is for what so I compiled this simple diagram.
Hope this helps.
Lou
1992 Trans Am
May 10, 2023 07:19 PM
IROCZ1989
Jan 24, 2016 03:55 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
apie2546
Aug 8, 2015 07:12 AM
92projectcamaro
Aug 6, 2015 01:20 PM
