Blinker issue
Old Apr 11, 2007 | 07:04 PM
transamrob86's Avatar
Car: 1986 Firebird
Engine: 2.8
Axle/Gears: 3.42s
Blinker issue
Ok first off I am not home with my car. I am just the middle man. My dad reminded me of a problem I was having with the blinker on my car. He said he would turn the blinker in one direction (he is old and couldnt remember) and it would just iluminate the arrow in the car but not blink. Any ideas?
Old Apr 11, 2007 | 07:42 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Blinker issue
Replace the flasher unit under the driver side dash. A $4.00 part at the most.
Old Apr 11, 2007 | 09:53 PM
Re: Blinker issue
If it blinks correctly on one side but the light stays on on the other side, it can't be the flasher.
It's because one of your light bulbs is out on the side that doesn't blink.
Change the burned-out bulb.
Old Apr 12, 2007 | 01:54 AM
Grim'91Z's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7L V8
Transmission: 700R4 Auto
Re: Blinker issue
Could be the socket, too. There's only one flasher relay for both turn signals, so if one still works correctly then it's the bulb or socket.
Old Apr 12, 2007 | 11:34 AM
redfire82's Avatar
Car: 84 camaro s/c
Engine: 305 slightly tweaked
Transmission: TH400
Axle/Gears: 3.42 single stripe
Re: Blinker issue
yup, they're right
Old Apr 21, 2007 | 07:57 PM
hardy2x3x's Avatar
Car: 89 formula
Engine: tpi 350
Re: Blinker issue
i am having this same problem, on my driver side in the front neither blinker blinks, they also do not come on when i have the park lights on. only the left turn signal arrow is solid inside the car no matter if i have the lever down for a left turn or if i just have the park lights on. however, the bulbs are not blown because they do come on and flash when i have my four ways on ... is this a socket issue, also, if so how do you fix that
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
