safety nuetral wires ?
Old Apr 12, 2007 | 03:46 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i belive my car has a vats problem ,however i replaced the entire wiring from another camaro w/ mine. there is a plug end that has a green/white ,orange,and a black wires now it runs along w/ my power window switches .if i jump the orange and green/w together the starter kicks over.the problem is there is no place for this plug to plug into ,i've searched all over safety nuetral switch connected to the shifter.i'm lost.
Old Apr 12, 2007 | 10:11 PM
Jza's Avatar
Jza
Re: safety nuetral wires ?
The park/neutral switch is a five (if i remember right) pin connector that connects directly to the shifter. If you grabbed the wiring out of a manual trans car for your automatic there might be some splicing you'll have to do.
Old Apr 13, 2007 | 06:37 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
no, it was an automatic. i've got the five point already plugged in.
Old Apr 13, 2007 | 06:48 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Never heard of or seen a plug like that. Hmm. Does it look home-made or stock?
The orange wire usually supplies power from the fuse box. And the green wire (should be pretty thick) goes from the starter enable relay and to the starter safety switch. This connector sure isn't the gear selector connector or clutch safety switch, I can say that with confidence. It could be some kind of a remote-start connector.
Got any pictures by any chance?
Lou
Old Apr 13, 2007 | 08:12 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
no ,no pics but it's definetly factory.
Old Apr 13, 2007 | 10:12 AM
BigBadLou's Avatar
Engine: TPI
Can you trace the wires and see where especially the green/white goes? I'd expect it to be spliced into the green/white on the shifter switch. This might be an aftermarket harness for a push-button-start feature of some kind (just guessing).
Lou
Street Lethal
Apr 30, 2019 12:14 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Ducati900ss
Sep 2, 2015 09:05 AM
slade5612
Aug 11, 2015 07:19 PM
