do i need to put in a fusible link on this?
Old Apr 19, 2007 | 02:17 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
there is a thick yellow wire coming from my blue ign. box on side of my colum,it has been cut but is wired to a y/red wire .i don't know if it had a fusible link in between the two or can i just put a bullet on them?
Old Apr 19, 2007 | 02:23 PM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
Re: do i need to put in a fusible link on this?
The only circuits that should have fusible links are one that are not breaker protected. Find out where it goes to and from.
Old Apr 19, 2007 | 04:22 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Where exactly is the box? On the left side of the column or on top of it? Because there are two thick yellow wires on the column, one for headlights, one for ignition.
The yellow/red wire seems like an add-on, maybe for an alarm or something.
Lou
Old Apr 20, 2007 | 03:28 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
it's on top. it looks like factory wiring. but i took apart the old harness and it has a solid yellow wire all the way down.
Old Apr 20, 2007 | 09:22 AM
BigBadLou's Avatar
Engine: TPI
That's the starter wire. If you have an alarm on that car, my guess would be it's for starter disable (if both ends of the cut yellow wire are connected to two separate yellow/red wires) or for remote start (if the yellow/red just "Tees" off the stock yellow wire.
Lou
Old Apr 20, 2007 | 07:27 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
well, maybe it had an alarm from the last owner and they took it out and just put those wires together?
Old Apr 20, 2007 | 10:58 PM
BigBadLou's Avatar
Engine: TPI
I'm not perfectly clear on what wire is connected to what. You said that the yellow wire was cut. So the two ends of it are now connected back together and the extra yellow/red wire is connected there as well?
In that case, try to disconnect the yellow/red and leave the two yellows connected and see if that disrupts anything. If not, it's most likely a leftover from an alarm system. Did you try to trace the yellow/red? Where did it go?
Lou
DiabolicalRS
Aug 26, 2015 07:35 AM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
g.l.mos
Aug 22, 2015 12:02 AM
