changing drivers side mirror?
Old Apr 21, 2007 | 12:34 AM
Pontiackid's Avatar
Car: trans am ws6
Engine: something special :)
Axle/Gears: 4.10 posi
my drivers side mirror has a big crack in it, i got a new mirrow, but how do i change it, i dont want to break anything.thanks
Old Apr 21, 2007 | 12:41 AM
strokermotor91's Avatar
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
Re: changing drivers side mirror?
In order to change the mirror you have to take the door panel off, with the window in the up position, you can access the nuts on the inside of the door shell for the mirror.
Old Apr 21, 2007 | 01:17 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
If your plan is to swap the entire mirror housing, then strokermotor91 is correct. You can replace just the mirror and plastic backing piece without removing the mirror housing.
Lon
Old Apr 21, 2007 | 09:23 AM
Pontiackid's Avatar
Car: trans am ws6
sorry for the confusion, im talking about the glass part. sorry about that. yes its very hard when i go to look to change lanes and there is a big crack lol.
Old Apr 21, 2007 | 01:35 PM
lonsal's Avatar
Move the mirror to the extreme limit of travel down and you'll see a cross-shaped metal piece that snaps into the molded plastic backing behind the mirror. Pop that free and the mirror and backign will come off. I've purchased replacement glass from Pep Boys for far less than the dealer charges. For the drivers side an aftermarket replacement mirror will be fine. I've noticed that the lettering on the passenger side of the aftermarket mirrors is a bit blurred compared to OEM. Once you've replaced the glass the entire mirror backing just snaps back onto that cross-shaped piece. Use a towel on the glass to protect you in case it breaks. Note, these instructions are valid for the later style mirrors. Early mirrors had a hidden screw under the mirror glass. You had to break the glass to remove them.
Lon
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
kyleb24
Aug 15, 2015 08:24 AM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
89FormulaMan
Aug 10, 2015 10:01 PM
