volts on iat sensor
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
volts on iat sensor
i just got back from a junk yard and i have 3 iat sensors, i went to put a muiltmeter to them to see if they are good. what should it read when i do this?
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: volts on iat sensor
Try this table, it shows resistance values depending on temperature the sensor is reading.
If the values are way out of range, do not use that sensor, it will make your engine run poorly.
Lou
Lou
ok thanks, now would i put the + and - from the multimeter onto where the sensor plugs into the connector?
Engine: TPI
That's a big 10-4.
Lou
P.S.: Make sure it's set on resistance (either autorange or somewhere in the 20k range).
Lou
on mine it has 200 2k 200k 20m for ohms
Engine: TPI
Choose the 200k then. At room temperature, e.g. 70 degF, you should be seeing 3.4 kOhms.
Lou
Lou
ok i just tested the four i have, 2 were 3.0, 1 was 2.9, 1 was 2.8. i am in my room temp is close to 70. should i just use one of the 3.0 one's?
Engine: TPI
If you want to make absolutely sure you pick the right one, I'd put them a pot of boiling water for a few minutes and then pull them out one by one and quickly measure the resistance. Then I'd repeat the measurement on all 3 after they've sat in the freezer overnight.
Whichever gives you the best results is your candidate.
Lou
P.S.: For the boiling point, you can switch the multimeter to 2K for better precision (the resistance should be in the 200 Ohm range). For the freezing point, switch back to 200K because you'll be expecting 25Kohm).
Lou
yeah i did something like that, but i used a lighter, i picked the one that went down and up the fastest.
Engine: TPI
Not necessarily the best way to check them. "Fastest" is no quantification of precision. (no personal offense meant here or anything, I'm just stating facts - I'm not great with words so don't take anything personally, please)
If you want to pick the best one, you would need to check the sensor readings at known temperatures. That way only you can know that it is working accurately enough.
Hope this helps.
Lou
Hope this helps.
Lou
[QUOTE=BigBabyLou;3317582]If you want to make absolutely sure you pick the right one, I'd put them a pot of boiling water for a few minutes and then pull them out one by one and quickly measure the resistance. Then I'd repeat the measurement on all 3 after they've sat in the freezer overnight.
QUOTE]
so the water won't hurt the sensor any?
QUOTE]
Engine: TPI
If we're talking about stock TPI IAT sensor, then no. Cuz those are (unfortunatelly) identical to the CTS sensor which is designed to be immersed in water. It's just a big chunk of metal with a plastic connector on it, that's all. The sensor sees higher temperatures than the boiling point, on a regular basis.
Lou
Lou
Lou
Lou
Engine: TPI
Dang, then you actually have the correct sensor!
Lucky you.
So in that case, I wouldn't boil them. You could still put them in the freezer and measure, no harm in that. If you were here in Texas, you could just take them outside and read the resistance for 110+ temperatures.
But I guess where you're at, you don't get anywhere near 110. Find a place with the highest temp that you can find (sauna??) and measure the senders there.
Sorry, I assumed you had a TPI system, your car being
91 350 and all. Not many 350 TBI engines out there.
Hope this helps.
Lou
Lucky you.
But I guess where you're at, you don't get anywhere near 110. Find a place with the highest temp that you can find (sauna??) and measure the senders there.Sorry, I assumed you had a TPI system, your car being
Hope this helps.
Lou
it gets up to 110 in nebraska not as much as texas though. lol i did have a 305 then swapped in a 350.
86White_T/A305
Sep 21, 2015 05:28 PM
