Laptop Interface
Old May 4, 2007 | 01:44 PM
Overcast32's Avatar
Engine: 305 TPI - LB9
Transmission: 700R
Laptop Interface
Do you guys know if there's a connector that allows a laptop to be plugged up to the onboard computer on a 1988 TA? Software as well - I'm not sure what all the capabilities may or may not be, but I'd like to be able to get ECM codes, etc..
Not even quite sure what you would call the connector off the top of my head. Friend of mine has one for his Jetta, so I know they exist.
Old May 8, 2007 | 09:07 AM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
Re: Laptop Interface
Okay, slow down here.
First, it's called an Assembly Line Diagnostic Connector(ALDL)
Second, to pull codes, you don't need a laptop.
Third, you should really look through the tech articles, stickys, and faq's. ALL of your answers are there.
Old May 8, 2007 | 09:09 AM
phoxetis's Avatar
Car: T/A
Engine: 5.0 v8 TPI
yeah I made one myself... if you're handy with a soldering iron ... it runs on diacom which is downloadable somewhere probably.... it's connected to the printer port. I posted a pic of it on the "can't read O2 sensor" topic, then you can see what it looks like.
the connector is called ALDL connector. I haven't found one yet, I use just the wires and put them in
for codes you won't need a laptop. Pull key out, short pins A+B, put key in and turn to "run" without cranking.
Old May 8, 2007 | 09:55 AM
Overcast32's Avatar
Transmission: 700R
Ok - thanks, I didn't see that one at first. TONS of info to pour over here. Thanks for the good info in any event, it'll give me a good spot to start
And actually - just a FYI on the various 'jumpers' I've seen for this - Autozone actually gives away a little 'key' that will jumper those two terminals just to make it easy.
Old May 8, 2007 | 09:58 AM
pizza_guy's Avatar
I've got a paper clip 6" from me. Even easier
CORV3TT3
Aug 23, 2015 11:26 AM
91B4C jacob
Apr 4, 2001 09:15 AM
shawn87gta
Feb 8, 2001 01:13 AM
jRaskell
Dec 30, 2000 12:33 AM
