Headlight problems+stereo problems
Old May 9, 2007 | 10:19 AM
Smizx7's Avatar
Car: 1988 DEI IROC Camaro
Engine: 5.7
Transmission: Viper Spec T56
I have a 88 camaro 5.7 w/ 37,xxx miles. My problems started as an amp install which was already installed when i got the car. After popping amp fuses at battery, the stereo deck began to turn off when the headlights were turn on. Finally when the stereo no longer turned on, i took it out. When i plugged the stereo wiring harness in to the deck i heard a clicking noise from in the dash. Now i have another problem - after installing xenon H4 headlights they are flashing (headlights) after about an hour of driving at night. I feel this is all related to the hack job amp install that came with the car. What could be causing this?
Old May 9, 2007 | 09:07 PM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Re: Headlight problems+stereo problems
Take a look at my post in this thread regarding flashing headlights and some trouble shooting tips. It could be that you headling problem is caused by a loose ground connection some where in the headling circuits.
https://www.thirdgen.org/forums/elec...ight=headlight
Dave
Old May 10, 2007 | 05:21 PM
klez's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L Ported SLP Runners and Intake
Transmission: 700r4 w/ shift kit
your power wire to your amp has been cut or something. in other words, it is shorted out somewhere between that fuse at the battery and your amp, causing the fuse to blow.
Old May 10, 2007 | 11:25 PM
Smizx7's Avatar
Engine: 5.7
But how does that explain how the stereo shuts off when the headlights are turned on?
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
