alternator wiring question
Old May 9, 2007 | 08:00 PM
specvgini's Avatar
Car: 1991 Formula
Engine: 5.7
Ok i have a question... on a standard third gen alternator used on a 5.7 tpi from a 90's up firebird/camaro, what are the two wires that run from the upper plug? I know the one on the back goes to the battery and charges it, but what do the wires on the plug go to? one is the power that runs to the starter i believe what does the other go to? is it a ground or a ignition on power wire?
Old May 10, 2007 | 09:40 PM
Brads RS's Avatar
Re: alternator wiring question
The red and brown wires go to the voltage regulater on the alt. The red is a battey supp. and the brown is the exciter wire (it turns the alt on).
Old May 10, 2007 | 09:53 PM
specvgini's Avatar
Car: 1991 Formula
Engine: 5.7
thanks, your right. I figured it out today, but it was screwing me up because even with the wires set up correctly, red battery, brown excite, i wasn't getting and voltage reading from the back stud where the big red wire would go. so i just said screw it and hooked it up anyways and it indeed charged the battery. thanks for replying.
Old May 14, 2007 | 01:24 PM
stuba's Avatar
Car: 84 Firebird/88 Formula
Engine: 2.5L Iron Duke/5.7L 350
Transmission: 5spd./Auto
Where does that brown wire hook up? I'm NEW to this motor, just a location would help... thanks!
Old May 16, 2007 | 01:55 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Usually runs inside to the in dash volt gauge.
Old May 16, 2007 | 03:51 PM
specvgini's Avatar
Car: 1991 Formula
Engine: 5.7
a wire that is only hot when the motor is running. i hooked mine up to a pink wire with black line. i think it used to be part of the injector harness.
eightsixseven
Dec 16, 2024 01:50 PM
Cleotiz
Jan 6, 2018 08:56 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
