What Gauge wire ?
Old May 14, 2007 | 07:47 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
What Gauge wire ?
What gauge wire should I use when installing oil pressure,tranny temp,water temp gauges ?
Old May 14, 2007 | 09:50 AM
randy4762's Avatar
Car: 2010 Camaro 2SS, 1994 Chevy Blazer
Engine: 6.2L, 355TBI
Axle/Gears: 3.42 posi, 3.73
Re: What Gauge wire ?
18 gauge would be sufficient as there is no major current involved. You could use smaller if you have it.
Randy
Old May 14, 2007 | 08:20 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Im assuming these are mechanical(analog) gauges. The oil pressure has a line for the oil pressure, tranny temp and water temp should have their own wire from the sender to the gauge already if its a mechanical gauge. If they've been cut, the gauge will no longer work.
However, if its a electric gauge, you just need to hook up power, and illumination. Those wires dont need to be very big. If you have wires that were removed from a vehicle (i know i do from some ive stripped), any wire will do just fine for your purpose, but remember, if your not sure, go a little bigger gauge than you think u need. Bigger is always safer, never smaller. In your case, any wire from a vehicle will do just fine.
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
rocn7roc
Sep 21, 2021 02:16 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Jk_Under
Aug 17, 2015 03:08 PM
