No lights on in instrument cluster?
Old May 20, 2007 | 12:43 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
None of the lights in my instrument cluster work except for my blinkers(which dont work correctly) and the lights that dim behind the gauges. What should i look for, an unplugged connector?
Old May 20, 2007 | 02:20 PM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
Re: No lights on in instrument cluster?
First, make sure your dimmer isn't turned all the way down. Then start checking fuses. When all lights are out, you've either lost power or ground. Check the easy stuff first and then post back.
Corky
Old May 21, 2007 | 06:40 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Fuses are good and the dimmer isnt all the way down. Where can i find these grounds that i need to look for?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Jeremys87
Jul 14, 2022 09:08 PM
fasteddi
Sep 10, 2015 09:32 AM
Jetmeck
Sep 4, 2015 12:29 AM
andy74
Sep 3, 2015 08:41 AM
