Alternator Humming!?!
Old Jun 2, 2007 | 01:56 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
I just got everything back together for a first startup. When the ignition is on my alternator hums. But only when the wiring connector is pressed inward. It started doing this and jiggling with the connector got it to quit doing it all the time.
I'm getting 12.55 volts at the battery, 12.50 after the kill switch, 12.49 to my distro block in the bay, and 12.49 to my alt. What could be going on here...nothing?
Old Jun 2, 2007 | 05:42 AM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
Re: Alternator Humming!?!
what was the last thing you did concerning the alternator?
Old Jun 2, 2007 | 10:05 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
I don't think I follow...(its early!)
Installed it?
Old Jun 2, 2007 | 02:57 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
no what did you do? Is it new or somthing? Or did it just start doing this out of the blue? take it to autozone for free and they will test it for you.
Old Jun 2, 2007 | 07:07 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
This alt is not new. Not old but not new. A friend has a busniess that rebuilds alts and starters and he built this one to 140 amps. It has never done this before.
Old Jun 6, 2007 | 08:48 PM
z28camaroracer's Avatar
Car: 84 Z28, 89 RS, 98 SS
Engine: 350 .060 over, 350 .040 over, LS1
Transmission: TH350, TH700r4, T56
Axle/Gears: 4.11 spool, 3.73 open, 3.42 posi
Looking at your voltage readings, it sounds like you have dailed diodes this will also cause a high pitch noise from the alt.
Old Jun 6, 2007 | 10:10 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
I couldn't get the voltage when the car ran for the extremely short time it did. But the voltage was fine with everything connected.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
