ECM
Old Jun 3, 2007 | 12:20 PM
raiders8498's Avatar
Car: 88 Trans Am
ECM
will the Ecm from the camaro fit a TA, does it have to be the same year or do they use the same one for many years
Old Jun 3, 2007 | 01:30 PM
88KARRV6's Avatar
Car: All sold :-(
Engine: None
Transmission: None
Axle/Gears: None
Re: ECM
As long as it has the same engine and transmission, and is from the same year car, (like 88 camaro to 88 firebird) It should work fine.
Depending on the engine you *might* be able to use a different year computer, but I am unsure which years will interchange.
Old Jun 3, 2007 | 02:11 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: ECM
if you have TPI, from 86 to 89 are interchangeable.
90-92 are interchangeable.
you will need the right MEMCAL for you application.
TBI used one ECM for 88, & a different ECM for 89-92
Old Jun 3, 2007 | 02:40 PM
Car: 88 Trans Am
Re: ECM
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
