MAF relay location help
Old Jun 4, 2007 | 02:01 PM
cronsformula350's Avatar
Car: 89 Formula L98 power
Engine: '96 subaru, opposed 4banger
Transmission: TH700R4, subaru 4WD
Axle/Gears: 3.27, just works
Hi everyone. I have replaced the MAF relays in my iroc-z, but one or two were a different style than the ones, I still have in my '89 formula 350. I believe that two had a weather pack seal on them, the models MR-82, are the ones I believe are the ones, I think those were also on the firewall. And the other model MR-22, was the one near the battery for the car, didn't have a weather pack connection.
I would check but, the weather outside right now is shitty, and raining like a mother! If you guys could let me know, the style and location of these three relays, that would be great.
If you see my site, on page one, you see what I have ordered. I am getting the head gaskets and the timing pointer tomorrow. I already have quite a bit of it back together, but if you could let me know, what the sensors look like on your '89's and newer, and the locations, for sure, that would help a lot right, now, so I can order them, if they don't have the ones I need.
If there like I said, the replacement MR-82, number 14078907 on the relay, which there are two of; and the other one, model MR-22, number 10067925, next to the car's battery, let me know, I'd appreciate it, since the cars covered and it's raining.
The car has two relays with nummber 8280, and 8 digit number 14089936, the other one, is on the firewall, I think it's the MAF power relay, but I'm not positive, would you guys with '89 Formula's and T/A's be able to tell me what relay you have on the firewall, it's next to the power brake booster.
Please let me know, I need to replace the one on the firewall, the other two, are on the passenger side, on the other side of where the battery is, those are fine, but I need the other one. I know that when I replaced the ones on my Iroc, two were the same, and the other was different so.
Help me out, I could use some, Thanks everyone!
my86bird
Oct 23, 2015 12:20 PM
64goatman
Sep 9, 2015 01:09 PM
Gunsbee
Sep 7, 2015 07:10 PM
tonys91rs
Sep 2, 2015 07:07 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
