Headlights pop up on parking light switch
Old Jun 13, 2007 | 09:59 AM
XxSgtReillyxX89's Avatar
Car: 91 Trans Bird
Engine: 3.1 MFI
Axle/Gears: Stock
I know on my friends Trans Am when he switches his parking lamps on his headlights don't flip up. But on my 91 Firebird they flip up and i don't like it. So here's the Q: On the 90's and up do they come up when i switch the parking lamps only or do i have a problem?
Old Jun 17, 2007 | 09:08 AM
Car: 91 Trans Bird
Engine: 3.1 MFI
Axle/Gears: Stock
Re: Headlights pop up on parking light switch
ttt
Old Jun 17, 2007 | 10:42 PM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
i'd say either the wiring is screwed up or you need a new headlight switch.
Old Jun 19, 2007 | 10:55 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
If your headlights don't light up when they flip up, the culprit is in the headlight door module.
You can quickly make sure that the yellow wire on the module doesn't have 12V on it with the park lamps on. Only the brown wire should have 12V at that point.
Hope this helps.
Lou
Old Jun 19, 2007 | 03:40 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I can tell you that more than one of my customers has repaired their headlight actuator assemblies using the headlight repair kits I manufacture and let me know that is also solved the problem you describe.
Lon Salgren
Top-Down Solutions
Old Jun 20, 2007 | 12:48 AM
KCGTA's Avatar
Car: 1989 GTA
Engine: 5.7 L L98
Axle/Gears: 2.77
Just a basic answer to your question, you should be able to run your fog lamps/parking lights independently of your headlights. All of the previous replies are good advice. I would tend to side with the switch itself on that, followed by the wiring next. The switch is less than $15, so isn't a bad experiment if you're not sure. If you haven't messed with your wiring at all, than it is really most likely the switch. Good luck.
Old Jun 20, 2007 | 01:39 PM
BigBadLou's Avatar
Engine: TPI
Just a heads up: if you turn on the parking lights and the head light pop up but do NOT light up, then it is not the headlight switch. If the headlights DO light up with the parking lights, though, then yes, it would be a very good indication of a bad headlight switch.
Hope this helps.
Lou
BRoss99
Aug 10, 2025 05:08 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
