no spark...
Old Jun 14, 2007 | 07:26 PM
Nick85Iroc's Avatar
Car: 85 Iroc-z Camaro
Engine: 327 HSR
Transmission: TH350
no spark...
85 camaro with a 327. in the last 2 months i put new heads, cam, lifters, HSR, timing chain. pretty much a whole new top end and the internal coiled was switched to an external one. when i first tried to start it up it wa getting spark but it was weak, tried it for a couple times and the tack pegged out.. then after that i noticed that i didnt plug in the 4 wire connector to the ditributor.. duh... and now there is no spark at all.. the wiring seems to be all good and there is a brand new distributor and coil. could i have fried the ecm?. the fuel pump primes when the ignition is turned on and 12 volts go to teh coil... also when i first tried starting it, it had a coil with a ground and the tach wire goin to the same connection and i read in chiltons that if it was grounded it could cause ignition or ecm problems... should i try a new ecm?
silentkillzr
May 12, 2014 09:03 PM
maxjivi05
Jul 28, 2012 09:42 PM
bobbyk3lly
Mar 16, 2012 11:34 AM
fitojdj
May 30, 2011 10:35 AM
joker37
Jul 16, 2002 05:03 PM
