SBC lower rpm misfire, revs pretty clean above 2500rpm.
Old May 6, 2014 | 08:58 AM
silentkillzr's Avatar
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
Alright my SBC is annoying me now, I let it sit for 1 week, didn't touch it. It used to start on a dime, Now its really hard to start and misfires and rumbles under 2000-2500 rpm. If i rev it up, it seems pretty clean. I did have a couple scorched boots but i replaced those. Cap and rotor is good, plugs have been swapped out, no vac leaks that i can see, valves are adjusted well, i have compression air fuel and spark... Any Ideas?
I did recently adjust the valves but this issue was consistent before that...
Old May 6, 2014 | 12:39 PM
Engine: 357
Re: SBC lower rpm misfire, revs pretty clean above 2500rpm.
I did find a little debris in the regulator when i disassembled it, Maybe i have some crap in my tank, going to take the carb apart later and inspect.
Old May 6, 2014 | 12:59 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Carbed?
EFI?
Stock?
Old May 6, 2014 | 01:00 PM
Engine: 357
Carbed, summit racing 750 vac secondary carb. Vac advanced MSD streetfire distributor. built 357 forged pistons, alum heads, etc.
Old May 12, 2014 | 11:53 AM
Engine: 357
Update:
I have tried:
New coil
New Rotor
known good dist
New ignition module
New plugs
New wires
Known good carb
There aren't vac leaks as far as i can tell ( need to confirm with vac gauge yet )
Cleaned out fuel filter
I have a suspicion my fuel pump may be on its way out, need to confirm
Old May 12, 2014 | 11:58 AM
midias's Avatar
what cam is in the engine? What is the timing?
Old May 12, 2014 | 12:09 PM
Engine: 357
initial timing is about 24-25 degrees
I have a .488/.510 234/244 duration
Camshaft: Performer RPM
Part #: #7102
It literally ran so perfect before i parked it, came back out to this issue, I dont get it.
Old May 12, 2014 | 08:38 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Part #: #7102
Whoa, how much initial timing?
Old May 12, 2014 | 09:03 PM
Engine: 357
Well its far past my tab. That's with vac advance hooked up I should say. Not initial
theshackle
Sep 17, 2020 08:26 AM
mdtoren
Aug 23, 2015 12:52 PM
db057
Aug 22, 2015 08:17 PM
mdtoren
Aug 16, 2015 05:45 PM
