Hatch unlock button
Old Jun 20, 2007 | 09:59 AM
t/adreams's Avatar
Car: '91 Trans Am
Engine: 350 Blueprint Engines Cruiser
Transmission: TKX 5 speed
Axle/Gears: 3:42
Hatch unlock button
Is the hatch unlock button only supposed to work when the car is turned off and in park?
I want to say that for a while, it worked when the car was running and in park, but I can't recall.
Old Jun 20, 2007 | 01:43 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Hatch unlock button
On an automatic, the only thing that matters should be the Park or Neutral position, yes.
But I've seen automatic cars that also go through the parking brake as an extra safety measure.
So a running engine shouldn't affect the hatch pop. But try pulling the parking brake too.
Hope this helps.
Lou
Old Jun 30, 2007 | 08:56 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
on most makes and models the electric hatch/trunk release solenoid circuit is energized at all times
transmission has nothing to do with this
lol
i have yet to come across any year make model that the release solenoid circuit was not energized at any given time, key in or not
good luck
Old Jul 1, 2007 | 01:19 AM
t/adreams's Avatar
Car: '91 Trans Am
Axle/Gears: 3:42
After a lot of observing, the trunk release only works when:
1. car is off, key in off position, in park
2. Car is in park with key out
3. Car in park with E brake up, key in.
Interesting, considering I never thought it was so developed that with the engine running, it'd have to have the e brake on. Either way, decent safety feature.
Old Jul 1, 2007 | 07:10 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
mine only works when the ign. is off . i always thought this was correct so you could not open hatch by mistake while underway . i have a t-5 trans. and power windows . i for one would not want to open hatch while operating windows on the interstate at 70 m.p.h. . anyone else ???
UNCLE TOM
Old Jul 1, 2007 | 10:52 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Mine ONLY works with the e-brake set, engine running or not. This pretty much assures that the car is not moving. This is with a T-5, automatics may be different. Not long ago I had a service center call to ask how to open the hatch (key doesn't work), they tend to leave the car in gear without setting the brake, and let the transmission hold it in place. The only way to open the hatch from the console is to set the park brake.
Old Jul 1, 2007 | 12:45 PM
BigBadLou's Avatar
Engine: TPI
Correct, automatics are different from T-5s. Or vice versa. On the factory T-5, the E-brake must be up. That's the ONLY safety feature. On the automatics, it's usually just the P or N position on the gear selector or sometimes the E-brake needs to be up too, depends on model/year/weather/constellation ...
Lou
Old Jul 1, 2007 | 08:04 PM
TurtleMacLeod's Avatar
Car: '91 Camaro RS
Engine: TBI 305
Okay, how about using the key at the back of the car? And on a related question, does the hatch and the passenger power window share any wiring? My car sat for a while, and the only two things that don't work now are the power hatch and the passenger power window.
Old Jul 2, 2007 | 01:23 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
The KEY is a mechanical release that releases the hatch hold down. There is no interface with the the electrical hatch release circuit.
The power windows and the hatch release are powered form differrent circuits, so no there should be no common point except power to the fuse block. Check and make sure the wiring connectors are firmly connected to the switches in the console.
Attached below is the wiring diagram for the hatch release for the 82 model Camaros. Manual transmissions only require that the parking brake be engaged. Automatic transmissions require that the shifter be in PARK or NEUTRAL. Note also that the circuit is always hot, not depending on what position the key is in the iginition switch. I have not seen any other wiring diagrams for the hatch release circuit in the Haynes Manual or at the AutoZone web site. It is also possible that GM changed the design in later model years to inclued the igntion switch and/or the e-brake in cars with auto transmissions.
Dave
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
jrdturbo
Mar 31, 2016 02:58 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
formula00ra
Sep 28, 2015 11:50 AM
Elephantismo
Sep 24, 2015 05:15 PM
