Power Window Wire help
Old Jul 18, 2007 | 01:24 AM
OS3Fleming's Avatar
Car: 1984 Camaro Z28
Engine: 357 SBC
I know we have killed this question, and yes searched but didn't find the answer. K got this door to replace mine, it had power windows that work, got a switch for it. No heres the problem I don't have a harness but will just use normal conectors for it. I don't know how the wires should link up to the switch
UP
______
______
Down
Using this simple diagram what wire goes where?
Thanks guys
Rich
Old Jul 19, 2007 | 04:50 PM
OS3Fleming's Avatar
Engine: 357 SBC
Re: Power Window Wire help
bump
Old Jul 19, 2007 | 06:24 PM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
UP
______
D B
C A
______
Down
A=window up
B=window down
C=ground
D= 12V key power
Old Jul 19, 2007 | 09:57 PM
OS3Fleming's Avatar
Engine: 357 SBC
Where do I get the power wire from. Can I use 14 and 18 gauge wire left overs......Thanks.
Old Jul 19, 2007 | 10:24 PM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
I would run a wire from the fuse box. 14 guage would probably be your best bet. As you are looking at the fuse box on the right side between the heater/ac and stop/hazard fuses you should see where the power windows ckt breaker would be, the opening just above a metal can that shaped like a fuse marked PWR ACC. One side will have power with the key on, tap into the other side for your power wire to the switches. You should get a 35Amp circuit breaker to put in the fuse box. Any parts house should have them.
Old Jul 19, 2007 | 10:43 PM
OS3Fleming's Avatar
Engine: 357 SBC
would I need to pull the full box down to do this or will it be pretty easy? This is the fist of this type of thing to do.
Old Jul 20, 2007 | 08:35 AM
OS3Fleming's Avatar
Engine: 357 SBC
bump
Old Jul 20, 2007 | 08:56 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Quit killing yourself,......... I've installed this set-up in an 86 and a 91 in the last month and it's pretty easy if you have the right stuff.
$20 + shipping.
* Buttons are $7 each
If your car is an 82-89 it will have a power junction bok behind the drivers kick panel. Plug this harness into the junction box and your done. Your fusebox is already wired and all you need to do is place a circuit breaker in the correct slot. ( looks like a metal fuse. )
I've also got a harness for Windows and locks as well for $35 + shiping.
If your interested just post your ZIP and I'll get a shipping qoute for you.
Old Jul 20, 2007 | 08:14 PM
OS3Fleming's Avatar
Engine: 357 SBC
66213
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
