Turn signal problem
Old Jul 18, 2007 | 02:08 PM
my82roc's Avatar
Car: 89 Iroc Convertible
Turn signal problem
I am having a strange problem with the turn signals in an 89 Iroc Convertible.When you hit the turn signal lever the front flashes one side and the inside on the cluster flashes one side but at the rear tail light both sides flash.Just like if you had the hazzards on.Any ideas what to look for?
Old Jul 18, 2007 | 04:29 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Turn signal problem
If the same behavior applies to both sides, even with the lights on, and if the hazard signals work flawlessly, then the problem is in the turn signal switch itself.
Hope this helps.
Lou
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
