non pulse wiper motor in a pulsing equiupped car?
Car: 1986 firebird
Transmission: THM350
I bought a new wiper motor for my car, a pulse one cause its what it had, but it never had a motor and I cant get a cover for it, but at our junkyard theres a bunch of wipermotors/cover, but there non pulse
can I put a nonpulse one in my car and have it work for its 3 speeds they have?
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: non pulse wiper motor in a pulsing equiupped car?
My 86 Coupe had a Pulse wiper from the factory, meaning that the column has the pulse cam for the stalk mounted control. I can install a pulse or a Non-pulse wiper system to the car and they will both work.
The Non-pulse will only work when set to the HIGH or LOW settings........ nothing will happen if you set it in the "intermittent" range. MIST should work fine as well as the washer pump.
Car: 1986 firebird
Would a non pulse cover fit on a a pulse motor?
Good question - I have no good answer !!!
I didn't "guinne pig" and of the motors I tested at the time because only 1 failed. It was late - and I just threw the dead one away !!!
All the motors I plugged in ( pulse and non-pulse ) were connected to a car that had the correct Pulse wiper control in the column.
colton_carlson
Mar 8, 2019 12:21 PM
1984, 84, berlinetta, boards, camaro, chevy, controller, low, motor, nonpulse, nonpulsewipers, pulse, wiper, wipers, work
