turn signal madness AARRGGHHH!
Old Aug 12, 2007 | 01:09 PM
owensrob's Avatar
I have an '85 Z28 and I can't get the front turn signal lights to work. Problems: 1) when head lights are turned on...rear indicators come on but front do not. 2) When turn signal switch is engaged the rear lights light (don't flash) but the front don't do either. 3) when hazard switch is activated, the rear lights flash but the front do not. Have tried so far: 1) replaced entire front light wiring harness 2) replaced all bulbs 3) replaced hazard flasher 4) replaced light fuses I am at my wits end. please email suggestions to owensrob (at) quantusamerica (dot) com thanks
Old Aug 18, 2007 | 05:37 PM
owensrob's Avatar
Re: turn signal madness AARRGGHHH!
**BUMP**anyone out there?I need to get this car inspected so that I can tag it and I am stumped.
Old Aug 19, 2007 | 06:00 PM
GTA Jim's Avatar
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
Axle/Gears: 3.27 Posi
Just for clarification.. Are the front and back park lights working, and the turn signals aren't? Or is it that neither the park lights or the turn signals come on?
Non working turn signal lights that have strange interactions with other lights are usually a symptom of a bad ground somewhere. When other lights are turned on, the signals are finding a path to ground through them.
The first thing I'd do is grab an ohm meter and measure the resistance between the metal frame of the turn signal bulb socket to a good solid ground on the body. There should only be a couple of ohms maximum. If there is resistance there, then the ground is bad. It's a good idea to pull the turn signal fuse or disconnect the battery when you do this.. If you get across 12 volts with an ohm meter, you can ruin it.
Once that's done, connect the battery or replace the fuse and put the meter in the Volts position. Now measure between the contacts at the base of the bulb socket and ground to see if you have 12 volts. (Have the park lights and turn signals on when you measure). You should see 12 volts on the contact pins on the bottom of the socket.
If you don't have 12 volts, then you'll have to trace the wires back to the fuses or flashers, or to the turn signal switch on the steering column to see why you don't have 12 Volts where you should.
Old Aug 21, 2007 | 09:45 PM
owensrob's Avatar
Neither the park lights or turnsignals are working. I had thought about the possibility of the bad ground becasue it looked like someone had been into the old harness. So, I replaced it. I made sure that the new harness was complete and that there was not a bare wire or corroded connection. I will say that the connection to the firewall connector was extremely difficult to make becasue of lack of room to work and the angle of attack. I haven't had time to run an ohm test but that is the plan for the weekend. Thanks for responding. I will let you know the results. O~
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
TrevinE
Sep 14, 2015 03:20 PM
