want to builb a knock readout unit
Old Aug 14, 2007 | 08:18 PM
jfg455's Avatar
Car: 89 formula *sold*
Engine: 305TPI
Axle/Gears: 3.45 9 bolt
Ok. I realize that this sounds weird but here goes. I am running a turbo motor with an aftermarket ecu (big stuff 3 ) and I wish to make a small readout board (like the screen on a scanmaster) so that I can monitor knock in real time. The ECU data logs so I don't really need to run a redundant unit such as a scanmaster but I would like to see the knock parameter in real time. Anyone have any ideas? Or am I on crack and should just use a scanmaster as a $400 monitor? thanks. John
Old Aug 15, 2007 | 03:32 PM
onesickss's Avatar
Re: want to builb a knock readout unit
do you want the actualy knock readout in numbers?if you are just worried about seeing a high or low reading why not check out the knock gauges everyone uses on GN's and turbo TA's it's a 2 1/16 gauge and goes from red to green depending on knock. you may also want to check summit cuz I'm pretty sure i have seen some knock meters.
Old Aug 15, 2007 | 03:58 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
MSD still makes one I think, Pretty cheap. Sensor and
and digital gauge.
We used them in our inboard boats with with over the transom headers. Noise, couldn't hear Worked great.
Just keep backing timing off until led lites quit lighting.
Had a little problem with flat tappets and rollers cams
with loose lashes though.
HTH
Old Aug 17, 2007 | 08:41 AM
jfg455's Avatar
Engine: 305TPI
Most of these gauges use the stock ECU knock module to power them. Unfortunatly, I am using a Big Stuff 3 ECU and I don't know if it will support the gauge. I did want to see it in numbers if possible but will settle for lights if that is what I can get.
Old Aug 17, 2007 | 10:34 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
You can power them with the stock knock module, which is seperate from the ECM.
Old Aug 17, 2007 | 10:56 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Old Aug 17, 2007 | 12:05 PM
jfg455's Avatar
Engine: 305TPI
That is the best idea I have heard yet. I was erroniously thinking that the module was in the ECM like the later R motor style ECM's. duh! Sometimes my brain thinks it is way to smart for the simple solutions. Thanks!
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
gord327
Oct 3, 2015 01:25 PM
ironbmt
Sep 27, 2015 06:00 AM
