tbi to carb. what to do with computer
Old Aug 16, 2007 | 06:29 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
i am about to swap to a carb on my tbi 350 in my 91 camaro rs. couple questions....what sensors will i need to leave on the motor? knock, cts, etc. also if i pull the computer will all my gauges still work inside? would it be better to leave the computer in there and just remove the wires that i don't need? thanks for ANY help!! -jon
Old Aug 17, 2007 | 03:16 PM
Re: tbi to carb. what to do with computer
ttt. 20 views no help?
Old Aug 17, 2007 | 05:30 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Patience is a virtue. This has also been covered thoroughly in the past 7 years making it easy to find in a search.
Also on this page, there are 2 similar posts to yours. Don't get upset because you didn't take the time to look for an answer.
To your question though. Nothing ECM related need to be kept when converting to carb. You'll need to obviously keep the oil sender (part of the OPswitch assy above the oil filter) and the water sincer (drivers side head, single green wire) if you are to retain function of your gauges.
In the event you ever want to revert to F.I (say, you sell the car), it's bet5ter to unplug the ECM harness and tuck it out of the way. Otherwise, trace all the sensor/injector/emission wires and cut.
92firebirdguy
Sep 1, 2016 07:53 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
Glowsock
Sep 11, 2015 11:09 PM
92rsvortec350
Sep 10, 2015 10:54 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
