Headlights work, not at right time.
Old Aug 20, 2007 | 04:13 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
OK, here it is, I changed all four of my headlights over to sylvania silver stars. Turned the lights on to see if I could tell a difference. Both lows came on. Fliped the brights on and both brights came on. Problem is when the brights are clicked on, the drivers side low clicks off, passenger low stays on though. Click bright off and the both lows come back on. What gives? all I did was change the headlights. 92 Camaro by the way.
Old Aug 20, 2007 | 06:44 PM
stevo the torpe's Avatar
Car: 91 maro
Axle/Gears: 373 locker
Re: Headlights work, not at right time.
check ur ground mounted behind the head lights that are mest up and check to see if ur light swicth is hot if it is its burning up and u need to get a diff headlight with a lil less power.and check to see if ur dimmer switch is hot it may be burnt up it is on the steering colume it has a rod running fromit to the steering wheel.
Ghettobird52
Jul 5, 2024 11:18 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Fronzizzle
Aug 19, 2015 01:36 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
stalkier
Aug 13, 2015 12:59 PM
