what kind of relay?
Old Sep 1, 2007 | 07:55 AM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
what kind of relay?
im trying to find a relay that has 2 12v input sources to turn it on...
what im trying to do is set up a relay to run my cooling fans and i need one that will turn on when the a/c comes on and i also have a temp probe that would turn it on when the engine gets over 180*
anyone know what relay i should use?
Old Sep 1, 2007 | 08:22 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: what kind of relay?
IT may be easier to make it like the stock setup and have on relay, and just make the temp switch and the AC switch supply a ground path. That way you can hook up both ground wires to a single relay terminal.
Old Sep 3, 2007 | 10:10 PM
onesickss's Avatar
you could just use two relays. one for the temp switch and one for the a/c or you can put both inputs together and diode isolate them so that they don;t feed back into eachother. I'd say stick with the two relays and then you can wire in a bypass switch into one of them to turn the fan on whenever you want.
Falcon50
Aug 22, 2020 03:26 PM
Gunner242
Dec 25, 2015 04:49 PM
thunder57
Nov 7, 2015 02:28 PM
hartsmike
Oct 2, 2015 07:11 AM
