temp gauge wiring
Old Sep 6, 2007 | 09:15 PM
C.M.Jones's Avatar
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
temp gauge wiring
I have and 84 camaro i'm trying to hook up the stock water temp gauge, does anyone know where the wires for the sending unit are, where they come out of the firewall, which side the stock sending unit is on a 84 Z28 H.O.?
Old Sep 7, 2007 | 08:46 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: temp gauge wiring
The temp gauge sensor is in the driver side head, between the first two spark plugs. The wire is dark green and goes into the loom and towards the driver side and enters the cab through the C100 bulkhead connector (pin F5) and to the gauge.
Btw, the wire splits in two on the inside of the C100. One goes to the temp gauge, the other one to the ignition switch.
Hope this helps.
Lou
(click image for bigger size)
Old Sep 7, 2007 | 11:25 AM
C.M.Jones's Avatar
the bulkhead connector; is that under the relay farm? so if I run a wire from P5 to the sensor we should be good?
my sensor pigtail has 2 wires, is one for ground? I thought it grounded to the block. The car I got the pigtail off of had an aluminum intake.
P.S. thanx for the schematic but I already have that in my book although mines not colored
Old Sep 7, 2007 | 11:47 AM
BigBadLou's Avatar
Engine: TPI
Yep, the C100 is in the corner by the brake booster, under the "relay farm" (that's quite fitting ).
You don't have a dark green wire in the engine harness? Look for F5 on the engine side of the C100 and trace it in the wire loom. Maybe somebody just cut it off or something.
Yes, you can connect the second wire to any good ground. Some sensors are grounded through their threads, some have an extra wire. Intake is never considered a good ground so GM usually puts two-prong sensors on it.
Lou
Old Sep 7, 2007 | 03:58 PM
C.M.Jones's Avatar
Is there a way to disconnect the harness from the engine side of the firewall?
Old Sep 9, 2007 | 06:36 PM
C.M.Jones's Avatar
.......B.U.M.P.
Old Sep 10, 2007 | 09:58 AM
BigBadLou's Avatar
Engine: TPI
Yes.
IIRC, there is a bolt through the connector so you'll need to undo it first (possibly 8mm). Then just pry and pull on the connector and it will eventually come off, depending on how much tar (yes, tar) somebody used to seal it.
Hope this helps.
Lou
rocn7roc
Sep 21, 2021 02:16 PM
Jote4805
Aug 25, 2015 06:11 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Jk_Under
Aug 17, 2015 03:08 PM
