using HEI distributor
Old Sep 8, 2007 | 04:13 PM
afida15's Avatar
im gonna use a toggle switch to turn the coil on...should i use a inline fuse? or just wire straight from batter to switch and from switch to coil?
Old Sep 8, 2007 | 04:22 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: using HEI distributor
A little more info on what you're trying to accomplish would be helpful.
Old Sep 8, 2007 | 04:53 PM
afida15's Avatar
well i took out all my TPI wiring harness and going with a Carb motor.using a HEI distributor u only need that one wire to turn on the coil. and id rather just use a hidden toggle switch to turn it on instead of hunting the ignition wire that goes from the key to the coil. so basically im just wantin to use a toggle switch to turn on a HEI coil..what gauge wire should i use and what amp switch and use a fuse or not?
Old Sep 8, 2007 | 04:58 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Just use the wire that supplied power to the stock HEI.
Old Sep 8, 2007 | 08:17 PM
afida15's Avatar
it didnt come with HEI stock..it had the TPI motor in it its a 1989 IRoc z 350
Old Sep 8, 2007 | 08:22 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, and that engine came with an HEI distributor. Every Chevy V8 with a distributor from 1975 had an HEI distributor.
Old Sep 8, 2007 | 08:26 PM
afida15's Avatar
isnt HEI wtih coil on top....cuz my coil was not on top it was to the side of the distributor on a bracket mounted to the intake....would there be anyway i could use that distributor without the computer
Old Sep 8, 2007 | 08:34 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, HEI is just a marketing name for all GM's electronic ignition distributors, which came in a variety of shapes and styles.
You can't use the original computer controlled distributor with a non-computer carb, but you can reuse some of the wiring. You don't need to take out the whole harness.
Old Sep 8, 2007 | 08:37 PM
afida15's Avatar
oh alright thank you tho..il try to find the ignition wire....my STARTER solinoid wire from the Key still works....but if i cant find the original ignition wire..what should i use then
Old Sep 8, 2007 | 08:52 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You'll find it. If not, you could find it under the dash on the other side of the firewall.
Old Sep 8, 2007 | 08:53 PM
afida15's Avatar
alrihgt thanks..il have to use my haynes manual and see what color the wire is
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
skinny z
Oct 5, 2015 06:23 PM
Damon
Sep 26, 2015 04:29 PM
