Pulse Wipers dont Pulse
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
my pulse wipers wont pulse!!! looked at a wire diagram and cant see what controls the pulse, do i repalce the motor or what? i got the RPO for pulse CD4 and and my car is all original never wrecked all vins matching so there is no chance of a junk yard special going on.
Car: 92 z28
Engine: fast burn 385
Transmission: t56
Re: Pulse Wipers dont Pulse
i have the same problem. i have had a few different blinker arms on the column and all have had the same problem, as soon as i go from lo or hi to any intermittent setting they just stop whereever they may be, just like if the car were turned off.
only thing i can think of doing is swapping the wiper motor and see if it does anything different. if you have time to do this please post an update as i dont have time to do it in the near future
100% EXACT SAME PROBLEM!!!!! i wish someone else had this problem and fixed it, i would hate to buy a new motor at aprox $70 and it not fix the problem, i have yet to replace my wiper/cruise arm, i want to, my writing is worn off.................im not sure of the the if its the arm or motor or the switch part, but the other day they wouldn't work for crap, i kept on going from off past delay to lo, and back again over and over and then they worked ok, but only on high and low, and the mist (single wipe you know turning it the other way than to delay~lo~hi)
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
(one of ) My camaro(s) has a Delay wiper arm, Delay column, and a NON-Delay motor. When I use my wipers they act EXACTLY as described above.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The motors are the same whether you have pulse or not. The wiper motor covers are different.
so that black cover houses the "brains"...........you know what the name of that part is so i can chack at my local auto parts house??
Engine: 383 Carb
Transmission: 4L60
It's called a wiper motor cover. I don't know if it'll be available from the aftermarket. On a pulse wiper system the cover has the electronics for the delay circuit. On a non-pulse system it only has the park switch.
The GM part number for it is 22063290. If you can find an parts store that carries AC Delco they should be able to order it by that number as well.
ok, there is no fuseable link or anything going to it, like on the high on the blower motor?? (i just fixed that problem for free lol) i cant see one like that looking in my wire diagram
Engine: 383 Carb
Transmission: 4L60
No, if you had a blown fuse you wouldn't have any wiper movement at all.
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
+1
When my wiper cover failed there was no pulse setting.
Mine is actually even more complicated because I have the digi-dash.. I couldnt find it anywhere and eventually had to get one from a board member.
Car: 92 z28
Transmission: t56
i cant find anything by that part number, i tried ac delco websites and it shows nothing, even tried doing a google search for the number. did anyone else yhave luck with it or is there a way to double check and make sure it wasnt just a typo?
Engine: 383 Carb
Transmission: 4L60
I could look again, but if you can't find it then it's probably NLA. You'll have to go used, unless the aftermarket is making them.
Car: 92 z28
Transmission: t56
are these covers the same on all 82-92 delay cars or are there differences? might just have to hit the junkyard in search of one
Engine: 383 Carb
Transmission: 4L60
No, 82-83 used the old massive motor with the external cowl-mounted pump that was in use since time immemorial. 84-87 used a motor with the internal pump, and 88-92 used a different motor with the in-reservoir pump.
This is proving harder than once thought? did you figure out the part nuber was right or wrong
AC Delco looked it up for me using year/make/model, and i got a Sorry sir we dont have it
Pep Boys has this http://www.partsxdirect.com/asearch.aspx?aid=547
WIPER MOTOR PULSE BOARD
MANUFACTURER:A1 REMFG INCPART NUMBER:81158P
A1 Remfg is CARDONE
no pic of part online
A1 Remfg is CARDONE
heck no, i did see that pic on the only wiper pulse board on JC Whitneys site, is that the one at pep boys?......how about the switch mec on the collum?? how can i test that or is there a switch mech in there?
Engine: 383 Carb
Transmission: 4L60
That's the Cardone 81-158P. Doesn't look like it's the right part for you.
well hells bells, i guess i need to go the used route
ok guys i have found some motor and cover units being sold as one on ebay item # 220172023914 on ebay motors looks like a good deal, sent seller a ??? about if its a pulse board or not.
I have looked at my wire diagram to make sure the pulse board is getting the right signal from the switch in the car but not sure of what to look for.... as in power to what color wire when switch is in delay/low/high, i got a multi meter incase it sends verious volts (lower than the normal 12 or so) to control the delay time, but does anyone know what kind of signal i should be looking for on the wires accord to the position of the switch inside the car, i guess to make a long question short how do i know if its the motor cover or the switch in the car??
also Gene, just in case you didnt get my e-mail, the control board is the black cover on the motor itself, there is a reply a few messages up from this one the tells you what years can be interchanged
ok here is a message Geno sent me via e-mail
Hey Man, did you ever get that pulse wiper figured out? I just replaced
my complete wiper motor assembly with one I got from Hawks ThirdGen
parts and the damned thing still won't pulse. Just low and high. The only
improvement I saw was when I pushed the windshield washer tab on the
turn signal lever the wipers move. They didn't before. Got any ideas?
I'm fresh out.
Regards, Geno.
ok so i see that he replaced it, and im 99% sure he had a new black box also on his, as he and i both knew we needed a black box but as you can see he still has problems,
mine i havent tried to fix, mine still works 100% on high and maybe 75% of the time on low or the mist (single pass) never on delay 100% all original no wrecks car with delay RPO so i know i have the right parts for it to work (it aint like someone put a delay arm in a non delay car), i would still like to know what kind of voltage i should have at what color wire (at the plug on the black box) according to the position of the lever inside anyone know? or is there a switch or brain inside the car that can go out and if so where is it?
I'm fresh out.
Regards, Geno.
oh yea talked to the original owner, never replaced the motor, or lever, but was having the trouble i mentioned on and off when he sold it to me, back in 2002 ............................... dang i owned the car over 5 years and only put about 26,000 miles on it LOL but i guess thats a good thing
knock knock
no one i guess, somebody has got to know something about this
still having issues here, geno's has a mind of its own?? SOMEONE HAS GOT TO KNOW!!!!! lol
Car: 92 z28
Transmission: t56
oh how nice it will be to once again have delay wipers in the rain, that is if i ever drive the car in the rain again
so i actually fixed the problem, it was the motor cover. i got 2 of them from a junkyard today and ran home and out one on, and it worked fine the few times i tried it.
the circuit boards inside looked diffeent on mine and the replacement, but it still worked. one of them has a number on it, i think its a gm number, but i tried it on gmpartsdirect and t wont pull anything up.
so now you at least know for sure this works, as long as the motor and everything else are fine. any other questions let me know
COOL!!!! i just wonder why GENO was still having problems with his? Thanks for telling me your results
Be careful when you remove and replace the cover. There's an arm underneath the cover that has to go back on the same way. If you install it the wrong way, it will swing around and snap the circuit board in the motor cover in pieces.
repalced the motor and cover today, wipers work perfect
1Aauto
Sponsored Vendors
Sep 23, 2015 01:09 PM
