ECU Clicking
Old Sep 10, 2007 | 10:11 AM
w4yn3st4tik's Avatar
ECU Clicking
Whenever I turn the key to activate power only, the ECU makes a very loud clicking noise. The also runs like garbage when it started clicking, so I think that might be the problem because I know its nothing under the hood.
Old Sep 10, 2007 | 07:27 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
Re: ECU Clicking
Ok.
Old Sep 12, 2007 | 12:17 AM
Re: ECU Clicking
wow thank you for your expertise
Old Sep 12, 2007 | 12:23 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: ECU Clicking
A little information would help. Year, make, model and engine configuration for a start.
Old Sep 12, 2007 | 09:41 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: ECU Clicking
Yes, a little information about yourself and your car goes a long way.
For starters, you could pull the ECM from under the dash and lay it on the floor. Then when you turn the key, try to find out which part of the ECM the clicking comes from. Or maybe it's coming from the dash by the ECM or maybe even from somewhere else.
If you determine it is the ECM for sure, you could swap it with somebody else's ECM and see if the sound goes away.
Lou
Old Sep 13, 2007 | 10:33 AM
Re: ECU Clicking
thank you very much. 88 trans am, tpi 350, automatic
RS Reaper
Oct 17, 2018 07:52 PM
KO1
16
Oct 15, 2015 05:00 PM
Linson
Oct 1, 2015 09:50 PM
sahlomonic
Sep 20, 2015 07:15 PM
