Can I add Cruise Control?
Old Sep 11, 2007 | 08:41 AM
ohiotemplar's Avatar
Car: 1992 Camaro RS V6
Engine: 3.1 V6 MFI
Axle/Gears: 3.23 stock
I really miss cruise control - my RS does have it - has anyone had success transplanting one from a junkyard car? Aftermarket kits?
Old Sep 12, 2007 | 10:42 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: Can I add Cruise Control?
I put one in an older Blazer, Audiovox, from Autozone. Worked great but it uses a small square control panel rather than the turn signal stalk switch.
Old Sep 13, 2007 | 01:13 AM
Engine: 3.1 V6 MFI
Thanks tom3!
Old Sep 13, 2007 | 01:16 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You could swap a factory cruise set up in without any huge problems. It would be easiest if you could get everything from a single donor car.
Old Sep 13, 2007 | 03:19 AM
Engine: 3.1 V6 MFI
What all would that intail? I would need the little signal stick and the cruise control unit, cables... what else? Also, would a fourth gen cc unit fit? It's more likly to work that a 15 yr old equivalent. thanks! - Nate
Old Sep 13, 2007 | 08:57 AM
Ice Fisherman's Avatar
Car: 91 Camaro
Engine: 191 V6
Transmission: 4L60
I did this myself in a 91. You need the turn signal stalk with the cruise switches, wiring from the switch thrugh the steering column, 2 brake pedal switches, cruise module, cruise servo, and two wiring harnesses, one from the cruise module to the brake switches, and another that is bundled with a vacuum hose that connects to the cruise servo.
Old Sep 13, 2007 | 09:57 PM
Engine: 3.1 V6 MFI
If I printed this and took it to the local junkyard, I'm sure they could get this stuff for me.
Old Sep 13, 2007 | 10:45 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you can, try to talk them into letting you take it off the car yourself. That way you get to see how everything is installed.
Old Sep 13, 2007 | 10:48 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
We have several pick and pull lots by me but not enough Camaros or Firebirds...
Old Sep 14, 2007 | 07:08 PM
Engine: 3.1 V6 MFI
our scrap yards seem expensive, hopefully I canfind a good deal.
Hotrodboba400
Dec 10, 2019 07:07 PM
tglennon11
Sep 23, 2015 05:30 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
