distributor wireing ,, NEED INFO
Old Sep 11, 2007 | 09:31 PM
karrfirebird87's Avatar
Engine: 350 4 boltmain goodwrench crate
Transmission: 350 turbo 3 speed
Axle/Gears: i belive its a 323 gear ratio posi
HI , IM RECENTLY SWAPT MY MOTORS IN MY 87 FIREBIRD FROM A 2.8 V6,MPFI,, TO A 350 GM GOODWRENCH CRATE MOTOR WITH HEI ,, BUT HERES THE PROBLEM I SEE AN ADDITIONAL SET OF WIRES COMEING OUT OF THE BACK SIDE OFF OF THE MODULE ,, IM NOT TALKING ABOUT THE COIL WIRE HARNESS, NOW I KNOW ITS A 7 PIN MODULE ,, AN ON MY OLD MODULE FOR THE V6 HAS A SMALLER SET OF WIRES BUT VERY SIMMALER , IS IT POSSIBLE TO RIG THESE WIRES THE DISTRIBUTOR FOR THE 350 IS OFF A 84 GMC 2500 VAN ,, SO ANYBODY NOW WHAT NEEDS TO BE DONE OR IF ANYTHING CAN BE DONE
Old Sep 12, 2007 | 01:35 PM
redfire82's Avatar
Car: 84 camaro s/c
Engine: 305 slightly tweaked
Transmission: TH400
Axle/Gears: 3.42 single stripe
Re: distributor wireing ,, NEED INFO
if it's like the one i put in my v6 car, I had to cut the connector off the pink wire and just use a regular spade type connector, but I'm not exactly sure what you're talking about with modules and such. do you have some pictures?
Old Sep 12, 2007 | 05:26 PM
sorry i dont have any pics of it ,, but the harness im talking about would plug into a computer controlled vehicle
Old Sep 14, 2007 | 05:41 PM
problemd solved ,, ill just need to get a new distributor ,, with a 4 pin module ,, you know plug an play type
Caspar
Jun 19, 2016 11:19 PM
g.l.mos
Aug 22, 2015 12:02 AM
355sbcTPI
Aug 19, 2015 04:38 PM
djmarch
Aug 19, 2015 12:07 PM
86IROC112
Aug 17, 2015 07:57 PM
