hot ground
Old Sep 14, 2007 | 08:30 PM
btjz28's Avatar
hot ground
i just put a 383 crate in my 84 and went to crank it and the ground wire off the battery got really hot and started smoking. Does anyone have a clue what it could be? how many wires run to the starter?
Old Sep 14, 2007 | 08:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: hot ground
The starter only needs 1 heavy cable to the battery and a wire for the solenoid to operate. The battery stud is used as a distribution point for all sorts of other engine wiring, though.
Which ground wire on the battery started smoking?
Old Sep 14, 2007 | 09:45 PM
btjz28's Avatar
Re: hot ground
The negative battery cable bolted to the body.
Old Sep 14, 2007 | 09:46 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: hot ground
You're missing the ground bolted to the engine.
Old Sep 14, 2007 | 09:52 PM
btjz28's Avatar
Re: hot ground
The wire that comes from the firewall to the intake?
Old Sep 14, 2007 | 10:04 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: hot ground
No, the one that goes directly from the battery terminal to the engine.
Old Sep 14, 2007 | 10:10 PM
btjz28's Avatar
Re: hot ground
Okay I'll check that. Thanks man.
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
tommy z-28
Oct 6, 2015 10:58 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
Glowsock
Sep 5, 2015 07:48 PM
