Bizarre Tach Problem
Old Sep 17, 2007 | 04:39 PM
JohnBlazeLTZ's Avatar
Car: 1993 Caprice LTZ
Engine: 350 TBI
Transmission: 4L60 (700R4)
Hey guys...I have a 1993 TBI 350 Caprice and I am having a tach problem. Yesterday I was cruising down the road at about 60 mph and the tach needle started fluttering...then it jumped down to 0 rpm's and stayed there for like 2 minutes before jumping back up to cruising rpm's. I have been told that the RPM sensor for the tach is located at the distributor? Is this correct? How would I go about diagnosing the condition? Any suggestions?
JB
Old Sep 17, 2007 | 05:11 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Bizarre Tach Problem
There's no "sensor" for the tach, the tach is wired directly to the coil primary. If you're having problems with it that aren't caused by a wiring fault, then the problem is with the tach itself.
Old Sep 17, 2007 | 05:28 PM
Engine: 350 TBI
Ah. Dang. I guess its a good thing I got a back up cluster laying around huh?
Thanks for the reply Apeiron.
JB
Old Sep 19, 2007 | 01:49 PM
Engine: 350 TBI
Apparently this is similar to how the tach takes its reading off the distributor:
http://en.wikipedia.org/wiki/Hall_effect_sensor
Old Sep 19, 2007 | 01:55 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Some distributors use hall-effect sensors, but that doesn't have a direct effect on the way the tach works.
Old Sep 19, 2007 | 02:02 PM
Engine: 350 TBI
O.K. I just found it online and wanted to post it up. I guess what I am wondering is if in the event that I needed a new cap and rotor...that the spark inside the cap may be arching and causing a weird reading. I am due for a tune up so...it has crossed my mind.
But...when I tap on the dash board...my tach jumps by me tapping my finger on the lead edge of the dash....so this indeed seems to confirm your idea that my tach in general may be going bad.
Old Sep 20, 2007 | 03:35 PM
Burntz's Avatar
Car: 1986 Trans Am
Engine: Mild 10:1 355.
Axle/Gears: 9 bolt
I had the same problem in mine, except it only did it when it was extremely cold, during the winter, as soon as the car warmed up it was fine
Kinda weird
Old Sep 20, 2007 | 03:46 PM
Engine: 350 TBI
Kinda weird
Yeah man. This old Cappy has seen better days. I hope it will at least get me through for another 6 months....I'll be in a lot better shape then to decide if I want to fix this car anymore or get rid of it. Kind of sad...car has been pretty good until this last year...many many headaches.
Old Sep 20, 2007 | 03:56 PM
Burntz's Avatar
Car: 1986 Trans Am
Axle/Gears: 9 bolt
Id just check the wiring, and its probably just the tach assembly. Its no biggie, I never really checked my tach anyway
Now doing a tranny swap to a th350, not doing the output shaft right to correspond with your speedo gear and having no speedometer
Thats a big deal haha.
Old Sep 20, 2007 | 04:07 PM
Engine: 350 TBI
Yeah...I got an extra cluster I picked up a while back. Hopefully that will solve it when the time comes.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
