electic fans
Old Sep 20, 2007 | 10:01 PM
micali's Avatar
Car: 1988 sport coupe
Engine: 2.8
Transmission: 700 r4
electic fans
My fans won't come on when my temp goes over 220 mark. If I shut the car off and then start it agian they will come on. Why is this?
Old Sep 22, 2007 | 01:28 PM
micali's Avatar
Engine: 2.8
Re: electic fans
Old Sep 22, 2007 | 03:03 PM
Tobashadow's Avatar
Re: electic fans
Sounds like stuck relay or stuck temp sensor.
Turn on AC and see if fans come on next time without restart. If they do then id lean more toward the sensor.
Old Sep 22, 2007 | 03:09 PM
streetlthl's Avatar
Re: electic fans
I has that problem with mine turns out it was the temp fan switch in the intake... theres 2 sensors ones for temp gauge and ones a fan switch.....
Old Sep 22, 2007 | 03:43 PM
micali's Avatar
Engine: 2.8
Re: electic fans
I tried grounding out the relay with the green/white wire and nothing happened. So I direct wired the fan and nothing. I used a piece of wire and a test light. I completed the circut because when I touched the test light to the post on the batt the light came on. I hooked one to the - on the batt and hooked the other side to the + of the battery. Fan motor must be bad.
The ac is not charged enough to turn on. I don't have a blower motor in the car at all, this couldn't make the ac not come on?
Old Sep 23, 2007 | 08:55 PM
streetlthl's Avatar
Re: electic fans
If you direct wired your fan pos and neg to the battery and it didnt come on..... thats a gimmie..... yeah getcha new one... By the way if you dont have a blower motor on your car that wont have any affect on the A/C system actually coming on... The compressor will still pull in and the cooling fan will still operate... the evap core will just have no air flow and probably freeze up after a few minutes.....
Old Oct 2, 2007 | 06:46 PM
micali's Avatar
Engine: 2.8
Re: electic fans
The blower motor is good. I hard wired it to the batt and it blows fine. I tried grounding the relay and that didn't make the fans come on. I am guessing that means the relay is bad.
Old Oct 2, 2007 | 07:57 PM
yevgenievich's Avatar
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
Re: electic fans
when the fans should turn on while the car is running check the black with red stripe wire after it goes out of relay to see if it have power, if it does then the fans are dead. Also check the orange wire that goes to the relay, it should have power all the time when ignition is on.
Old Oct 2, 2007 | 09:33 PM
micali's Avatar
Engine: 2.8
Re: electic fans
sorry about that I meant Fan motor is good. The blower motor is another issue.
Old Oct 6, 2007 | 04:51 PM
micali's Avatar
Engine: 2.8
Re: electic fans
I was grounding the wrong relay, I grounded the correct one and the fans came on. So what else can I check to get the fans on.
Old Oct 6, 2007 | 07:06 PM
vbMike's Avatar
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
Re: electic fans
You fans may be setup different than mine but I have two fans. The smaller one is computer control and the larger fan is controlled by a temp switch that screws into the passenger side head. You might want to check that switch in the head to make sure it is working. It is just one wire, I believe it just completes a ground.
Old Oct 8, 2007 | 09:37 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: electic fans
You may also want to check the CTS (Coolant Temperature Sensor) on the front of the engine, right under the TB. It has a two-wire connector. Check the connector for oxidation/corrosion, check the wires.
If you have an ohm-meter, measure the resistance of the CTS with the engine cold, warm and hot (write down the temp and measured resistance).
If the CTS is bad, the ECM won't know that your engine is hot and won't turn the fans on.
I'm not saying this is exactly what's wrong with your cooling fan circuit but it's one of the common problems to check for.
Lou
Old Oct 8, 2007 | 07:35 PM
micali's Avatar
Engine: 2.8
Re: electic fans
now the fans won't come on at all. I grounded the relay with a switch so I can turn them on when the temp gets near 220.
Old Oct 12, 2007 | 09:34 PM
IroczInOz's Avatar
Re: electic fans
Try and hook up 12v to the fan directly and see if they come on. If they do then you most likely have relay problem.
Old Oct 13, 2007 | 06:09 PM
micali's Avatar
Engine: 2.8
Re: electic fans
The relay is good, I've got a switch groundng the relay so I can maulally kick on the fans.
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
