Distributor Adjustment TPI
Old Sep 21, 2007 | 12:35 PM
rodie_27's Avatar
Car: '89 IROC convertible
Engine: 355 TPI
Axle/Gears: 3.45? Posi
Me and a buddy were checking my timing the other day and found, much to my dismay, that it was advanced about 25*. Shouldn't be all that big of deal, loosen up the 9/16" bolt and dial it in. Well, with the TPI setup, there's all kinds of 'stuff' in the way. Any ideas about how to loosen the bolt up? Any specialized tools needed? Also, I'm assuming the stock 0* is the best timing?
Old Sep 21, 2007 | 12:43 PM
shawnc16's Avatar
Car: 86 IROC, 89 GTA
Engine: 350 blocks, both of em
Transmission: 700r4s
Axle/Gears: 10 bolt and 9 bolt, 3.73, 3.23
Re: Distributor Adjustment TPI
Last time i checked 6 degrees initial.. disconnect the single wire on the passenger side rear near the firewall/ A/C, I believe the wire is brown.
Old Sep 21, 2007 | 12:45 PM
rodie_27's Avatar
Engine: 355 TPI
Ok, so disconnect the wire to allow easier access and then set my timing to 6* advance?
Old Sep 21, 2007 | 01:04 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Disconnecting the wire cuts the ECM off from controlling the timing. Its a brown wire right up above the heater box, has a weatherpack connector. Unplug it, loosen dist bolt (craftsman makes a "Distributor Wrench" which has a nice offset to reach it easy) then set your timing to 6* advance. Plug brown wire back in, then disconnect battery to clear the trouble code.
Old Sep 21, 2007 | 01:06 PM
shawnc16's Avatar
Always gotta top me Matt.. haha
Old Sep 21, 2007 | 01:58 PM
rodie_27's Avatar
Engine: 355 TPI
Great, thanks a lot for the info! I'm going to go see what I can do to get that done. Thanks again!
Old Sep 24, 2007 | 11:42 PM
PV9685's Avatar
Car: 89 Firebird Formula
Engine: 305 Vortec, Single-plane, 4 barrel
Transmission: T5, soon 700R4
Axle/Gears: 88 10 Bolt, Disc, Auburn, 3.23
When the bypass wire is unplugged, should the ignition module still advance?
I get 4 degrees at idle, if I give it just a HAIR of throttle, like, 100 RPMs up, I get 6 degrees; if I put it at like 2k I get 12 degrees. Is this weird?
My chain also must be worn because the timing mark bounces about a degree or two back and fourth between revolutions.
-Dave
Old Sep 24, 2007 | 11:48 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There's a small amount of advance built into the module, so that doesn't sound too unusual. The end-play in the distributor usually allows for a few degrees of variability in timing, you can disassemble the distributor and shim it down to reduce it.
Old Sep 25, 2007 | 07:27 AM
PV9685's Avatar
Thank You,
I noticed quite a bit of free play in the distributor, but I figured that more or less it would be taken up when in motion.
-Dave
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
86IROC112
Aug 17, 2015 02:00 PM
Out-Cast
Aug 17, 2015 10:57 AM
Sanjay
Aug 12, 2015 03:41 PM
