Removing an alarm: issues.
Old Sep 23, 2007 | 08:43 PM
White93z34's Avatar
Car: 1987 Camaro IROC-Z
Engine: LB9
i've been working on a 91' RS with a 305 recently, and aside of the many problems the car has it has(had) a old Clifford alarm installed, and it was a very hacked installation, anyhow i got mad at it and tore it all out today. the loudspeaker, brain, shock sensors everything. at this point i have 90% of the cars wiring as it ought to be....
however, now the hatch release no longer functions properly, if i ground the brown wire to the chassis it will release, but if i hook the switch up properly and press it, it fails to release, and the air bag lamp flashes then goes away.
any ideas on what someone did to this car?
Old Sep 26, 2007 | 06:54 PM
White93z34's Avatar
Engine: LB9
Re: Removing an alarm: issues.
ok, whats more is when i removed the alarm i had to reconnect the yellow wire the installer used as the starter disable, now the car refuses to try and start!
what is going on here!!!
Old Sep 26, 2007 | 07:56 PM
sikZ28's Avatar
Car: 86 Trans Am
What did you hook up the yellow wire back to, the brains?
Old Sep 26, 2007 | 08:42 PM
White93z34's Avatar
Engine: LB9
no the starter kill was between this one yellow wire that came from the column, i took out the starter kill wiring, and patched the wire back together.
Old Sep 27, 2007 | 08:24 PM
sikZ28's Avatar
Car: 86 Trans Am
Should have worked then, could the problem be elsewhere?
I removed the alarm on mine a few months ago, but the car is at my parents or I would be able to go out to it and see what I did so I could help you out better.
Come on guys, help this dude.
Old Sep 27, 2007 | 08:30 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
How large of a gague is that Yellow wire? The hatch is easy. That alarm just had a trigger for a 2nd output. That wire you are toucing to make the hatch pop is the gnd trigger. It should go to an aftermarket relay, so you are going to need to trace it where it goes. In a Camaro the hatch button should be in the console forward of the lid. Look under there for a relay added. Remove and connect the factory wires back like they should be. IDK how without looking at it, they couldve rigged it so that the button wouldne control the hatch even without the alarm. But in this business Ive seen alot of ghetto crap. Get back with what you find
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
Fronzizzle
Sep 8, 2015 12:10 PM
