reverse lights problem
Car: 91 Camaro RS
Engine: 305 TPI conversion.
the car is my 91 5spd. all original. the lights used to work and quit a while ago. the bulbs, connections and wiring look good. the switch on the trans was turned and connection checked. possibly a bad switch?
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: reverse lights problem
Easy to replace, just did one on my 92 a couple of weeks ago. Same indications for me - both lights just quit working at the same time. You will leak a little tranny fluid when you pull the switch, have the new one ready to put in as soon as you pull the old one out.
