700r4 to th400 how to hook up mech to electic speedometer??
Old Oct 2, 2007 | 07:50 AM
camaroracer1992's Avatar
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
i am converting from a 700r4 to a th400, is there a how to etc on how to convert the mechanical drive on the th400 to the vss of a th700?? Thanks
Old Oct 22, 2007 | 06:51 AM
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
Re: 700r4 to th400 how to hook up mech to electic speedometer??
cmoin can anyone help me??? i have searched with no success on the site and the internet. Thanks guys!!!
Old Oct 23, 2007 | 04:31 PM
Aaron_SK's Avatar
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
http://ls1tech.com/forums/showthread.php?t=197642
It's more common to see fourth gens keep the electronic speedo, since most thirdgens where cable.
Old Oct 25, 2008 | 10:47 PM
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
i installed the painless wiring adaptor and also the gears. the gears mesh well and i cant get a reading on the speedometer. what wires am i supposed to hook to where? thanks in advance
Old Oct 27, 2008 | 09:13 PM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Here is my problem i am putting in a newer 700r4 tranny in replace of my 1986 700r4. they both are 30 spline. but the one i am putting in is electronic how can i convert back to cable on the electronic speedo sensor. i heard you can pull the cable module off and put it in replace the electronic sensor is this true?. any info please need help. i have both transmissions out so it wont' be hard to do just need info if i need to do any modifications?
Old Oct 30, 2008 | 09:42 AM
yeah low's Avatar
If yours is like mine, you can swap them out, yes. Borg Warner has a part with BOTH TYPES of connections on it, in case you should ever need. I cannot recall the part number, but I remember that it cost about $100 or so, and It was stocked in a couple O'Reilly Warehouses nationwide. Might take a couple days for them to network it to ya, but really is a cool idea!
Scott AKA YL
Old Nov 1, 2008 | 02:36 AM
berlin305's Avatar
:P tranny is not manual. its automatic but thank you for the input they swapped out no problems going to have to have one of my friends clock me to find out if the speedometer is correct or not but seems like everythign work out great. ty for the info tho.
Old Nov 2, 2008 | 09:04 PM
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
no one has ever done this????
$750 L98
Feb 1, 2025 02:25 PM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
indygene
Sep 26, 2015 11:21 AM
Dragonsys
Sep 25, 2015 03:51 PM
6998poncho
Sep 25, 2015 02:56 PM
