anyone run the timing retard on a msd digital 6 plus?
Old Oct 2, 2007 | 08:35 AM
mean83z's Avatar
Car: 83 Z28
Engine: 355 c.i.
Transmission: TH350 3200 stall
Axle/Gears: 4.10's
I just hooked up my digital 6 plus system (6520) after I rebuilt my small block. I run nitrous at the track. There is an option to run a timing retard. I wired the pink wire from the box into my full throttle switch that runs to my nitrous solenoids. The retard works, but how well? The timing it pulls back is dead on as far as the numbers go. But does it pull it back quick enough to run the retard on the WOT switch when I hit the nitrous? I guess what I'm trying to say is, I dont want to hit the nitrous and not have my timing pulled back.
Old Oct 3, 2007 | 06:41 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Re: anyone run the timing retard on a msd digital 6 plus?
I wouldn't chance it that way myself.
I plan to wire it into the arming switch itself. I don't wanna chance the juice flowing before the timing is pulled out by using the WOT switch. I have a few nitrous junkie friends that have ran it this way as well for years now with no problems.
Old Oct 4, 2007 | 08:23 AM
mean83z's Avatar
Car: 83 Z28
Engine: 355 c.i.
Axle/Gears: 4.10's
sorry i read my post again, i actually wired into my arming switch like you said, my WOT switch doesnt have power untill I hit that switch anyways. So I guess the timing gets pulled back in time then?
Old Oct 4, 2007 | 09:43 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Transmission: Powerglide
Axle/Gears: 3.55
i have a digital 6 on my s10. 355 motor 12.4:1 and a 225 shot went 9.93 at 134.98. with the retard pulling 9.9deg.
Old Oct 8, 2007 | 07:26 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Yup, as soon as the system is armed and the motor is over 2000 rpm the timing gets pulled out by the box.
mattsv8_03..nice times on that shot!
Old Oct 15, 2007 | 02:28 PM
mean83z's Avatar
Car: 83 Z28
Engine: 355 c.i.
Axle/Gears: 4.10's
yup, the box def. worked, 11.7x@118 on friday, thanks
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
justin57
Aug 20, 2015 07:05 PM
Randomtask2
Aug 13, 2015 01:57 AM
beachrodder
Aug 7, 2015 04:27 PM
