STARTER PROBLEMS
Old Oct 3, 2007 | 08:18 PM
fbirdracer7790's Avatar
STARTER PROBLEMS
I am having some intermittent starter problems.. every morning it works fine, but if i drive around a little and turn it off and try to start it again, it sometimes wont work. I dont even have a click sound from it at all.. my radio and lights all work fine. I recently had thought i found the issue with a loose stud on the solenoid, but it happened again. since there are no relays on my car I am out of ideas on what it could be.
Old Oct 8, 2007 | 07:14 PM
Decayed312's Avatar
Car: 88 Camaro T-Tops
Engine: 305 TBI
Axle/Gears: 3.23 Limited Slip
Re: STARTER PROBLEMS
This may seem stupid but it worked for me, check the power post which is located between the radiator and the battery (on mine at least) mine was all rusted, shined it up never had an issue since
Old Oct 8, 2007 | 09:20 PM
kerplunk318's Avatar
Does it only not turn when its hot? Do you have headers? you may need a heat shield or blanket for the starter.
Old Oct 8, 2007 | 09:26 PM
ill try the power post idea.. yes i do have headers and custom exhaust, but i do have a starter heat blanket and it still has the same problem... it will always start up if i give it about 15- 20 minutes to cool off and it starts right up.. thanks for the ideas
Old Oct 8, 2007 | 09:45 PM
Travis&camaro's Avatar
Car: 1984 Camaro
Engine: BIG BAD 360!!!!
Transmission: th350 shift kit 3600 stall
Axle/Gears: 3:73 posi
You may just need a new starter my car did the same thing and I put a new starter in and and made sure all the conections were good and she started good when it was hot.
Old Oct 9, 2007 | 06:41 AM
yeah i had heard that too.. except i just put in a new starter about 2 days ago and it even still wouldnt start when it was hot.. during the winter, i have not a single problem with it.. its only when its hot and i live in florida, so it gets very hot, but thanks for the advice
Spyder_TheGamer
Dec 25, 2015 05:07 PM
5spdcamaro
Aug 28, 2015 02:12 AM
92camaroJoe
Aug 13, 2015 06:07 AM
milk
Aug 10, 2015 06:26 PM
