NEW GAUGE CLUSTER
Old Oct 10, 2007 | 01:26 PM
daghstdrummer's Avatar
Car: 1986 Z28 Camaro, 2002 Audi A4 (DD)
Engine: 350 .30 over w/bang for buck combo
Axle/Gears: stock for now
NEW GAUGE CLUSTER
Has anyone wired up new gauges into the car? Speedo Tach etc..?
i have an 86 z28 none of the gauges worked when i got he car and am in the process of swapping the 305 out for a 350 still carbed but i also noticed that the wiring harness on thec ar has a wire for tpi etc i want to rip all that un necessary stuff out and just keep what i need.
any ideas?
Old Oct 10, 2007 | 05:40 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
Re: NEW GAUGE CLUSTER
Are you buying the IROC cluster?
Old Oct 10, 2007 | 11:51 PM
no i plan on installing Autometer gauges(speedo, tach fuel oil water etc..)
Old Oct 11, 2007 | 11:34 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
Mech or electrical? I was gonna use mechanical I would rather rely on em.
Old Oct 15, 2007 | 08:23 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
If your going to be using Autometer gauges you can get rid of pretty much everything, since Autometer gauges come with new sending units. If I was you I would get rid of everything except the turn signal wires and probably the tach wire, and the original ground and power wires.
RS Reaper
Oct 17, 2018 07:52 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
