turn signal always on
Old Oct 15, 2007 | 08:54 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
my right turn signal indicator stays on when i turn on the lights. it doesnt flash just stays lite my turn signals work fine and there arnt any bulbs out . Any ideas why. thanks
Old Oct 15, 2007 | 09:39 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: turn signal always on
recheck all the bulbs and connections , i will bet you will find dirty connections some where . just re-clean all connections and check grounds . a little di-electric grease on cleaned contacts is always good . maybe a bad power lead somewhere , but i think just poor connections . LOL
Old Oct 15, 2007 | 09:58 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Had the same problem, signals worked fine, but the dash indicator was lit dimly with the lights on. Turns out the previous owner in his infinite wisdom had installed an incorrect bulb in the side marker. What I found there was something much larger than a 194 with the same wedge base. The bulb I pulled out was, I think, a 921 and was forced against the side marker lens. I only noticed it because there was a hot spot on the lens. Since the bulb was too big, it sat at an angle (the only way it could go) and created a slight short across the socket. Needless to say, I had to replace the bulb and the socket which was toasted by then.
Old Oct 15, 2007 | 10:01 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
my trans am did this. When the lights were on on turn signal indicator stay lit up. The cause a burnt out front turn signal bulb the rear turn signal still flashed though.
Old Oct 16, 2007 | 05:41 PM
redfire82's Avatar
Car: 84 camaro s/c
Engine: 305 slightly tweaked
Transmission: TH400
Axle/Gears: 3.42 single stripe
try checking the gasket under your dash cluster around the turn indicator, light may be spilling from the dash lights to the turn signal indicator
Old Oct 16, 2007 | 09:16 PM
1bad86z28's Avatar
Car: 86 I.R.O.C.
Engine: 40 over TPI 305
Axle/Gears: 3:73
My Camaro did the same thing only both arrows stayed lit up, the car had the wrong parking/turn signal bulbs, the base was the same but the glass was different. I put in the right bulbs and my turn signals started working and the arrows aren't lit up all the time now.
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
TrevinE
Sep 14, 2015 03:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
