(Frustrated) starting problem
Old Oct 23, 2007 | 05:15 PM
19redbird89's Avatar
Car: 1989 Pontiac Trans Am GTA
Axle/Gears: 3.23 9 bolt
I have posted before about a starting problem but since then I did get the car started. But now I get nothing from the car after I turn the keypast the initial starting point. So far the following parts were replaced Starter, Coil, battery, and ignition switch on the column. Now, when I turn the key the steering wheel unlocks and the fuel pump comes on but the when I turn the key I get nothing. It obviously drains the power. The transmission will not even shift our of park. I checked the ignition fuse but it was good. I guess what I need is a trouble shooting list or a friend. Any help would be great.
Brandon
Old Oct 23, 2007 | 05:36 PM
hattmuber's Avatar
Car: 91`camaro RS
Engine: 5.7l vortec T.B.I.
Transmission: STS 700r4
Axle/Gears: 9bolt-3.27
Re: (Frustrated) starting problem
tranny wont shift huh??? do you have an electric hatch or remote hatch?
Old Oct 23, 2007 | 06:07 PM
I have an elctric hatch
Old Oct 25, 2007 | 01:43 PM
Ok, I have the car able to start now. It will still not come out of Park unless I push down the switch with force. The button lets the cable move but not past the point where it will engage reverse. Any ideas?
Old Oct 25, 2007 | 03:41 PM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Look at your ignition switch. The shift lock cable (the cable that prevents you from switching out of park when the key isn't in) is attached to the ignition switch. Maybe the switch is busted which would also prevent you from starting it before.
Old Oct 26, 2007 | 10:59 PM
i can cancel this thread I have the car started with a little bti of work on the ignition switch but now I am losing power after I turn the car off. I am trying to figure out if it is a bad hatch motor not shutting off all the way. Something. I jsut do not have the power to turn the starter over and crank the motor. I am just going part to part testing and listening. Hopefully I find the issue. I am going to check the hatch tomorrow, and then I was thinking about looking into a strong starter?
92camaroJoe
Jul 29, 2023 07:57 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
