wats this box
Car: 85 camaro z28
Transmission: auto to manaul
wats this box
in my 85 camaro theres a sliver box right beside of my ecm, almost attacted. anyone knows wat it does???
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: wats this box
got any pics?Or maybe some more info would help.Does it appear to be a factory part?Are there any numbers on it?How many connectors are on it?Not trying to sound like a smart a**,but the more info you provide the better help you will recieve.
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Re: wats this box
If your car has or had a power antenna for the radio, it could be a relay assocaited with the power circuit for the antenna motor.
But, as TIMMYS89GTA noted it could be any number of things. So help us help you, by providing some more info.
Dave
Dave
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: wats this box
If it is a TPI 1985, it is the MAF BURNOFF CONTROLLER, A 1985 ONLY affair.
VERY COOL ! I noticed this little silver box when I stripped the computer wiring harness from my (now crushed) 85 TPI Trans Am. Had no idea what it was and was not in any hurry to find out...... The whole set-up was put into storage for later use.
Now I know - THANX !!!
